Neuigkeiten:
Hauptmenü
conrad verkauft "Renkforce WH2600" - kompatibel mit?
Begonnen von derdigge, 08.07.2015, 01:30:59
⏪ vorheriges - nächstes ⏩
goodfidelity
I tried to read about it in the link you send me but don't really find info on how everything hooks up and works together.
Does the Weewx get the information FROM the IP station, byt accessing the IP station live update page, or does the Weewx simulate wunderground server and get the information from the IP station POST feature?
I am really interested in knowing the setup in practice. Does the Weewx need the local IP address of the IP station? Or does the IP station connect straight into the linux computer?
Would be nice if someone could share their setup if they have similar weather station (WH2600).
Thanks for all the advice so far!
Zitat von: falk am 23.10.2015, 12:36:23
Zitat von: goodfidelity am 22.10.2015, 23:22:01
I dont understand how weewx is working, is it getting the data direct from the weather station, or is it getting the data from the IP-HUB? Is it fetching the data from simply reading the webserver on the IP-HUB?
Weewx retrieves the wh2600 weather data either from an apache web server or directly over ip. Same method you are already using.
https://github.com/dkmcode/weewx-observerip
falk
There are two different modes.
Direct mode: The driver communicates with the ObserverIP hardware over UDP
Indirect mode: The driver receives the weather date from a php skript. This one looks like the WU webservice.
But I am not sure in this. I don't know the WH2600
leliep
Hi zusammen, ich bin neu hier und gerade dabei, viel zum Thema Wetter und Wetterstationen zu lernen.
Nachdem ich mit großem Enthusiasmus eine Nexus mit Raspi und Weewx aufgebaut und in Betrieb genommen habe, muss ich leider feststellen, dass die Funkverbindung zwischen Basis und Windsensor grottenschlecht und unzuverlässig ist.
Selbst nachdem ich die Nexus Basisstation direkt unter's Dach platziert habe, kommt es immer wieder zu Ausfällen (ja, ich habe alle möglichen Positionen getestet und keine entscheidende Verbesserung erzielen können).
Daher denke ich nun darüber nach, statt der Nexus eine andere Station zu kaufen. Was bisher an dieser Stelle über die WH2600 zu lesen ist, hört sich nicht schlecht an.
Der Umstieg auf ein anderes System macht natürlich nur Sinn, wenn das neue System eine Verbesserung beim Funkempfang bringt.
Frage: gibt es inzwischen bei Euch Erfahrungen zur Verbindungsqualität und der Qualität im Allgemeinen der WH2600?
Danke für Eure Hilfe, -pl
Buxi
Hallo leliep,
Ich vermute mal der Windmesser wurde auf dem Dach montiert und die Basisstation steht genau senkrecht darunter. Dies ist die denkbar schlechteste Anordnung, da die Sendeantenne waagrecht abstrahlt und die Empfangsantenne aus waagrechter Richtung empfängt; also kommt unten kaum etwas an.
Sind am Windmesser und der Basisstation neigbare Antennen dran, dann neige beide mal um 90° in die Waagrechte, so dass beide Antennen mit der Breitseite aufeinander ausgerichtet sind.
Wenn das nichts hilft, dann kannst du einen besseren Empfänger für sehr wenig Geld nachrüsten. Hier u. A. das Thema: http://www.wetterstationen.info/forum/mebus-irox-nexus-cresta/umbauanleitung-tfa-nexus-superhet-rx-4mm3f/msg279746/#msg279746
Viele User hier haben in eingebaut und haben danach besseren Empfang, bzw. größere Reichweite. Eine passende Umbauanleitung gibt es bei mir auf Anforderung.
So schnell würde ich die Nexus nicht abstoßen, denn sie ist im Grunde genommen keine schlechte Station!
Gruß, Burkhardt xxxx
leliep
Hi Buxi,
das hört sich gut an. Ich hatte selbst schon die Beobachtung gemacht, dass der Empfang direkt unter dem Windsensor besonders schlecht ist.
Dann werde ich als nächstes mal die Antennenstummel parallel zueinander ausrichten. Den Umbau gehe ich dann ebenfalls an, kann ja nicht schaden, da auch die Thermo/Hygro-Sensoren zu Ausfällen neigen.
Danke für den Link auf die Empfängermodule, werde mir direkt einen bestellen.
Darf ich dann freundlichst um die Zusendung der Umbauanleitung bitten? Herzlichen Dank und beste Grüße!
Buxi
Gerne sende ich dir die Anleitung zu, doch das geht nur über eine E-Mail Adresse. Teile mir diese per PN/PM mit.
Hat sich erledigt, ich sehe gerade, dass du mich schon angeschrieben hast.
Jo Tin
ich hätte da noch ein paar Fragen zu dem direkten/indirekten abholen der Daten.
Muss beides mal ein Zielserver konfiguriert sein, bzw. wie müssen die Einstellungen im Gerät sein?
Welchen Weg würdet ihr empfehlen? Ich werde da aus den Anleitungen nicht ganz schlau.
MfG Jo
Urs Eppenberger
Danke für die wertvollen Diskussionen zu diesem Thema.
Ich plane, diese Wetterstation zu kaufen.
Ich habe selber gebastelte Temperatur-Sensoren (ESP201 mit DHT22) im Haus. Diese senden die Daten über WiFi zum RaspberryPi. Node-Red verarbeitet die Daten in einem graphischen Interface. Danach werden sie an emonCMS weitergereicht für die Speicherung und Darstellung.
Mit der Wetterstation will ich nun die Daten von draussen noch sammeln und dazu anzeigen. Bei Interesse melde ich mich mal wieder hier mit dem Fortschritt.
Urs.
ph2
Zitat von: derdigge am 11.10.2015, 10:00:51
Insgesamt muss man sagen, das Gerät liefert gute daten. Regensensor, Temperatur und Luftfeuchte stimmen mit analogen Geräte zu 99% überein. Für den Preis glaube ich voll ok.
Den Sonnenstrahlungsmesser kann ich nicht bewerten, jedoch scheinen die Daten plausibel.
Hallo!
Habe mir die Renkforce zum Testen zugelegt und sende die Daten vorerst einmal auf Wunderground.
Die Daten sind aber aus meiner Sicht nicht schlüssig, wobei es nicht unbedingt am Gerät, sondern (wahrscheinlich eher) an der Auswertung durch Wunderground liegen dürfte. Die Fehler habe ich auf meiner Station festgestellt, und dann auf der immer wieder zitierten Station IBERLINB43 bestätigt gefunden.
Z.B. Wind am 2.7.2016:
Lt. Zusammenfassung höchste Windgeschwindigkeit 17 km/h, Spitze 28 km/h.
Lt. darunter angezeigtem Diagramm ist die höchste Windgeschwindigkeit 11,6 km/h um 15:31 und die Spitze zur gleichen Zeit 15,8 km/h gewesen.
Und wenn ich dann noch auf die Seite http://wetter.mxberlin.de/dailyhistory.php gehe, dann sehe ich, dass am 2.7.2016 die höchste Windgeschwindigkeit 8,2 km/h um 13:00 und die Spitze ebenfalls um 13:00 11,8 km/h war. D.h., drei unterschiedliche Werte! Eine Möglichkeit dafür wäre, dass die Auswertungszyklen unterschiedlich sind. Aber dann haben diese chronologischen Daten keine wirkliche Aussagekraft, bei meiner Station haben die max. Windgeschwindigkeiten um bis zu 15 km/h differiert.
mackaroni
Hallo Leute!
Bei dem Versuch ein Firmware-Update der Renkforce WH-2600 durchzuführen, blieb dieses hängen! :x
Seitdem ist die Basisstation nicht mehr im Netzwerk sichtbar... :eek:
Reset und ping auf die statische Adresse war auch nicht erfolgreich?  :confused:
Hat jemand einen Vorschlag?
