foshkplugin.conf einrichten
Für Linuxbenutzer und -begeisterte
Hat sich bedankt: 45 mal
Danksagung erhalten: 516 mal
Re: foshkplugin.conf einrichten
in Zeile 65 steht [Station]
Hast Du das Config-File unter Windows und ggf. mit einem ungeeigneten Editor geaendert?
Wieviele [Station] Eintraege hast Du denn in Deiner Config?
Ansonsten wuerde es eine Hilfe deutlich erleichtern, wenn Du das komplette File mal mit anhaengen wuerdest.
wetterkunde
Beitrag von wetterkunde »
Hallo Oliver, ich habe nur den code aus dem Forum kopiert und in die weewx.conf eingefügt.
# WEEWX CONFIGURATION FILE
# Copyright (c) 2009-2021 Tom Keffer <tkeffer@gmail.com>
# See the file LICENSE.txt for your rights.
# This section is for general configuration information.
# Set to 1 for extra debug info, otherwise comment it out or set to zero
debug = 0
# Root directory of the weewx data file hierarchy for this station
WEEWX_ROOT = /home/weewx
# Whether to log successful operations
log_success = True
# Whether to log unsuccessful operations
log_failure = True
# How long to wait before timing out a socket (FTP, HTTP) connection
socket_timeout = 20
# Do not modify this. It is used when installing and updating weewx.
version = 4.6.2
#   This section is for information about the station.
[Station]
    # Description of the station location
    location = Pöhl Neudörfel
    # Latitude in decimal degrees. Negative for southern hemisphere
    latitude = 50.561087
    # Longitude in decimal degrees. Negative for western hemisphere.
 longitude = 12.201553
    # Altitude of the station, with the unit it is in. This is used only
    # if the hardware cannot supply a value.
    altitude = 390, meter    # Choose 'foot' or 'meter' for unit
    # Set to type of station hardware. There must be a corresponding stanza
    # in this file, which includes a value for the 'driver' option.
    station_type = Interceptor
    # If you have a website, you may specify an URL
    station_url = http://poehlwetter.ddns.net
    # If you have a website, you may specify an URL. This is required if you
    # intend to register your station.
    # The start of the rain year (1=January; 10=October, etc.). This is
    # downloaded from the station if the hardware supports it.
    rain_year_start = 1
    # Start of week (0=Monday, 6=Sunday)
    week_start = 6
[Station]
    # in this file with a 'driver' parameter indicating the driver to be used.
[Interceptor]
    # This section is for the network traffic interceptor driver.
    # The driver to use:
    driver = user.interceptor
    device_type = ecowitt-client
    port = 8573  # diese Portnummer weil die Daten via FOSHKplugin kommen, default wäre 80
 iface = eth0
    #iface = wlan0
    [[sensor_map_extensions]]
        co2 = co2
        co2_Temp = tf_co2
        co2_Hum = humi_co2
        co2_Batt = co2_batt
    # Specify the hardware device to capture.  Options include:
    #   acurite-bridge - acurite internet bridge, smarthub, or access
    #   observer - fine offset WH2600/HP1000/HP1003, ambient WS2902
    #   lw30x - oregon scientific LW301/LW302
    #   lacrosse-bridge - lacrosse GW1000U/C84612 internet bridge
    #   ecowitt-client - any hardware that uses the ecowitt protocol
    #   wu-client - any hardware that uses the weather underground protocol
    device_type = acurite-bridge
[Simulator]
    # This section is for the weewx weather station simulator
    # The time (in seconds) between LOOP packets.
    loop_interval = 2.5
    # The simulator mode can be either 'simulator' or 'generator'.
    # Real-time simulator. Sleep between each LOOP packet.
    mode = simulator
    # Generator.  Emit LOOP packets as fast as possible (useful for testing).
    #mode = generator
    # The start time. Format is YYYY-mm-ddTHH:MM. If not specified, the default
    # is to use the present time.
    #start = 2011-01-01T00:00
    driver = weewx.drivers.simulator
#   This section is for uploading data to Internet sites
[StdRESTful]
    [[StationRegistry]]
        # To register this weather station with weewx, set this to true,
        # then fill out option 'station_url' above.
        register_this_station = true
    [[AWEKAS]]
        # This section is for configuring posts to AWEKAS.
        # If you wish to post to AWEKAS, set the option 'enable' to true, then specify a username
        # and password. To guard against parsing errors, put the password in quotes.
        enable = false
        username = replace_me
        password = replace_me
    [[CWOP]]
        # This section is for configuring posts to CWOP.
        # If you wish to post to CWOP, set the option 'enable' to true,
        # then specify the station ID (e.g., CW1234).
        enable = false
        station = replace_me
        # If this is an APRS (radio amateur) station, specify the
        # passcode (e.g., 12345). Otherwise, ignore.
        passcode = replace_me
    [[PWSweather]]
        # This section is for configuring posts to PWSweather.com.
        # If you wish to post to PWSweather.com, set the option 'enable' to true, then specify a
        # station and password. To guard against parsing errors, put the password in quotes.
        enable = false
    [[WOW]]
        # This section is for configuring posts to WOW.
        # If you wish to post to WOW, set the option 'enable' to true, then specify a station and
        # password. To guard against parsing errors, put the password in quotes.
        enable = false
    [[Wunderground]]
        # This section is for configuring posts to the Weather Underground.
        # If you wish to post to the Weather Underground, set the option 'enable' to true,  then
        # specify a station (e.g., 'KORHOODR3') and password. To guard against parsing errors, put
        # the password in quotes.
        enable = false
        # If you plan on using wunderfixer, set the following
        # to your API key:
        api_key = replace_me
        # Set the following to True to have weewx use the WU "Rapidfire"
        # protocol. Not all hardware can support it. See the User's Guide.
        rapidfire = False
#   This section specifies what reports, using which skins, to generate.
[StdReport]
    # Where the skins reside, relative to WEEWX_ROOT
 HTML_ROOT = public_html
    # The database binding indicates which data should be used in reports.
    data_binding = wx_binding
    # Whether to log a successful operation
    log_success = True
    # Whether to log an unsuccessful operation
    log_failure = True
    # Each of the following subsections defines a report that will be run.
    # See the customizing guide to change the units, plot types and line
    # colors, modify the fonts, display additional sensor data, and other
    # customizations. Many of those changes can be made here by overriding
    # parameters, or by modifying templates within the skin itself.
    [[SeasonsReport]]
        # The SeasonsReport uses the 'Seasons' skin, which contains the
        # images, templates and plots for the report.
        skin = Seasons
        enable = false
    [[SmartphoneReport]]
        # The SmartphoneReport uses the 'Smartphone' skin, and the images and
        # files are placed in a dedicated subdirectory.
        skin = Smartphone
        enable = false
        HTML_ROOT = public_html/smartphone
    [[MobileReport]]
        # The MobileReport uses the 'Mobile' skin, and the images and files
        # are placed in a dedicated subdirectory.
        skin = Mobile
        enable = false
        HTML_ROOT = public_html/mobile
    [[StandardReport]]
 # This is the old "Standard" skin. By default, it is not enabled.
        skin = Rabenwetter
        enable = true
        HTML_ROOT = public_html/Rabenwetter
    [[FTP]]
        # FTP'ing the results to a webserver is treated as just another report,
        # albeit one with an unusual report generator!
        skin = Ftp
        # If you wish to use FTP, set "enable" to "true", then
        # fill out the next four lines.
        # Use quotes around passwords to guard against parsing errors.
        enable = false
        user = replace_me
        server = replace_me    # The ftp server name, e.g, www.myserver.org
        path = replace_me    # The destination directory, e.g., /weather
        # Set to True for an FTP over TLS (FTPS) connection. Not all servers
        # support this.
        secure_ftp = False
        # To upload files from something other than what HTML_ROOT is set
        # to above, specify a different HTML_ROOT here.
        #HTML_ROOT = public_html
        # Most FTP servers use port 21
        port = 21
        # Set to 1 to use passive mode, zero for active mode
        passive = 1
    [[RSYNC]]
        # rsync'ing to a webserver is treated as just another report
        skin = Rsync
        # If you wish to use rsync, you must configure passwordless ssh using
        # public/private key authentication from the user account that weewx
        # runs to the user account on the remote machine where the files
        # will be copied.
        # If you wish to use rsync, set "enable" to "true", then
        # fill out server, user, and path.
        # The server should appear in your .ssh/config file.
        # The user is the username used in the identity file.
        # The path is the destination directory, such as /var/www/html/weather.
        # Be sure that the user has write permissions on the destination!
        enable = false
        server = replace_me
        user = replace_me
        path = replace_me
        # Rsync can be configured to remove files from the remote server if
        # they don't exist under HTML_ROOT locally. USE WITH CAUTION: if you
        # make a mistake in the remote path, you could could unintentionally
        # cause unrelated files to be deleted. Set to 1 to enable remote file
        # deletion, zero to allow files to accumulate remotely.
        delete = 0
    # Options in the [[Defaults]] section below will apply to all reports.
    # What follows are a few of the more popular options you may want to
    # uncomment, then change.
    [[Defaults]]
        # Which language to use for all reports. Not all skins support all languages.
        # You can override this for individual reports.
        lang = en
        # Which unit system to use for all reports. Choices are 'us', 'metric', or 'metricwx'.
        unit_system = metricwx
        [[[Units]]]
            # Option "unit_system" above sets the general unit system, but overriding specific unit
            # groups is possible. These are popular choices. Uncomment and set as appropriate.
            # NB: The unit is always in the singular. I.e., 'mile_per_hour',
            # NOT 'miles_per_hour'
            [[[[Groups]]]]
                # group_altitude     = meter              # Options are 'foot' or 'meter'
                # group_pressure     = mbar               # Options are 'inHg', 'mmHg', 'mbar', or 'hPa'
                # group_rain         = mm                 # Options are 'inch', 'cm', or 'mm'
                # group_rainrate     = mm_per_hour        # Options are 'inch_per_hour', 'cm_per_hour', or 'mm_per_hour'
                # group_temperature  = degree_C           # Options are 'degree_C', 'degree_F', or 'degree_K'
                # The following line is used to keep the above lines indented properly.
                # It can be ignored.
                unused = unused
            # Uncommenting the following section frequently results in more
            # attractive formatting of times and dates, but may not work in
            # your locale.
            [[[[TimeFormats]]]]
                # day        = %H:%M
                # week       = %H:%M on %A
                # month      = %d-%b-%Y %H:%M
                # year       = %d-%b-%Y %H:%M
                # rainyear   = %d-%b-%Y %H:%M
                # current    = %d-%b-%Y %H:%M
                # ephem_day  = %H:%M
                # ephem_year = %d-%b-%Y %H:%M
                unused = unused
        [[[Labels]]]
 # Users frequently change the labels for these observation types
            [[[[Generic]]]]
                # inHumidity     = Inside Humidity
                # inTemp         = Inside Temperature
                # outHumidity    = Outside Humidity
                # outTemp        = Outside Temperature
                # extraTemp1     = Temperature1
                # extraTemp2     = Temperature2
                # extraTemp3     = Temperature3
                unused = unused
#   This service acts as a filter, converting the unit system coming from
#   the hardware to a unit system in the database.
[StdConvert]
    # The target_unit affects only the unit system in the database. Once
    # chosen it cannot be changed without converting the entire database.
    # Modification of target_unit after starting weewx will result in
    # corrupt data - the database will contain a mix of US and METRIC data.
    # The value of target_unit does not affect the unit system for
    # reporting - reports can display US, Metric, or any combination of units.
    # In most cases, target_unit should be left as the default: US
    # In particular, those migrating from a standard wview installation
    # should use US since that is what the wview database contains.
    # DO NOT MODIFY THIS VALUE UNLESS YOU KNOW WHAT YOU ARE DOING!
    target_unit = US    # Options are 'US', 'METRICWX', or 'METRIC'
#   This section can adjust data using calibration expressions.
[StdCalibrate]
    [[Corrections]]
        # For each type, an arbitrary calibration expression can be given.
        # It should be in the units defined in the StdConvert section.
        # Example:
        foo = foo + 0.2
#   This section is for quality control checks. If units are not specified,
#   values must be in the units defined in the StdConvert section.
[StdQC]
    [[MinMax]]
        barometer = 26, 32.5, inHg
        pressure = 24, 34.5, inHg
        outTemp = -40, 120, degree_F
        inTemp = 10, 120, degree_F
        outHumidity = 0, 100
        inHumidity = 0, 100
        windSpeed = 0, 120, mile_per_hour
        rain = 0, 10, inch
#   This section controls the origin of derived values.
[StdWXCalculate]
    [[Calculations]]
        # How to calculate derived quantities.  Possible values are:
        #  hardware        - use the value provided by hardware
  #  software        - use the value calculated by weewx
        #  prefer_hardware - use value provide by hardware if available,
        #                      otherwise use value calculated by weewx
        pressure = prefer_hardware
        altimeter = prefer_hardware
        appTemp = prefer_hardware
        barometer = prefer_hardware
        cloudbase = prefer_hardware
        dewpoint = prefer_hardware
        ET = prefer_hardware
        heatindex = prefer_hardware
        humidex = prefer_hardware
        inDewpoint = prefer_hardware
        maxSolarRad = prefer_hardware
        rainRate = prefer_hardware
        windchill = prefer_hardware
        windrun = prefer_hardware
#   For hardware that supports it, this section controls how often the
#   onboard clock gets updated.
[StdTimeSynch]
    # How often to check the weather station clock for drift (in seconds)
    clock_check = 14400
    # How much it can drift before we will correct it (in seconds)
    max_drift = 5
#   This section is for configuring the archive service.
[StdArchive]
    # If the station hardware supports data logging then the archive interval
    # will be downloaded from the station. Otherwise, specify it (in seconds).
    archive_interval = 300
    # If possible, new archive records are downloaded from the station
    # hardware. If the hardware does not support this, then new archive
    # records will be generated in software.
    # Set the following to "software" to force software record generation.
    record_generation = hardware
    # Whether to include LOOP data in hi/low statistics
    loop_hilo = True
    # The data binding used to save archive records
    # Whether to log successful archive operations
    log_success = True
    # Whether to log unsuccessful archive operations
    log_failure = True
#   This section binds a data store to a database.
[DataBindings]
    [[wx_binding]]
        # The database must match one of the sections in [Databases].
        # This is likely to be the only option you would want to change.
        database = archive_sqlite
        # The name of the table within the database
        table_name = archive
        # The manager handles aggregation of data for historical summaries
        manager = weewx.manager.DaySummaryManager
        # The schema defines the structure of the database.
        # It is *only* used when the database is created.
 schema = schemas.wview_extended.schema
#   This section defines various databases.
[Databases]
    # A SQLite database is simply a single file
    [[archive_sqlite]]
        database_name = weewx.sdb
        database_type = SQLite
    # MySQL
    [[archive_mysql]]
        database_type = MySQL
#   This section defines defaults for the different types of databases.
[DatabaseTypes]
    # Defaults for SQLite databases
    [[SQLite]]
        driver = weedb.sqlite
        # Directory in which the database files are located
        SQLITE_ROOT = %(WEEWX_ROOT)s/archive
    # Defaults for MySQL databases
    [[MySQL]]
        driver = weedb.mysql
        # The host where the database is located
        host = localhost
        # The user name for logging in to the host
        user = weewx
        # The password (use quotes to guard against parsing errors)
  password = weewx
#   This section configures the internal weewx engine.
[Engine]
    # The following section specifies which services should be run and in what order.
    [[Services]]
        prep_services = weewx.engine.StdTimeSynch
        data_services = ,
        process_services = weewx.engine.StdConvert, weewx.engine.StdCalibrate, weewx.engine.StdQC, weewx.wxservices.StdWXCalculate
        xtype_services = weewx.wxxtypes.StdWXXTypes, weewx.wxxtypes.StdPressureCooker, weewx.wxxtypes.StdRainRater, weewx.wxxtypes.StdDelta
        archive_services = weewx.engine.StdArchive
        restful_services = weewx.restx.StdStationRegistry, weewx.restx.StdWunderground, weewx.restx.StdPWSweather, weewx.restx.StdCWOP, weewx.restx.StdWOW, weewx.restx>
        report_services = weewx.engine.StdPrint, weewx.engine.StdRepor
Wenn ich das lösche
[Station]
dann startet weewx.
Wenn ich das lösche
Das passt ja auch zur Fehlermeldung mit Zeile 65. Du hast zwei Bereiche [Station] in der Config.
Mach Dir mal eine Kopie Deiner aktuellen weewx.conf und versuch mal die beigefuegte.
Ich habe da eigentlich nur den ueberzaehligen Station-Bereich entfernt bzw. zusammengefuehrt.
Ach ja, als Hinweis:
Ich wuerde den Wochenbeginn auf Montag legen - also week_start = 0. Und wenn Du im weewx.conf-File als Eingangsport 8573 definierst (Interceptor\port) dann solltest Du im Forward zu weewx in der foshkplugin.conf auch diesen Port angeben.
debug = 0
log_success = True
log_failure = True
socket_timeout = 20
version = 4.6.2
[Station]
    rain_year_start = 1
    week_start = 6
    # Oliver: ich wuerde hier 0 empfehlen!
[Interceptor]
    port = 8573  # default ist 8000
    iface = eth0
    #iface = wlan0 # Oliver: wenn Verbindung ueber WLAN-device stattfinden soll, dies und Zeile oberhalb aendern
        co2 = co2
        co2_Temp = tf_co2
        co2_Hum = humi_co2
        co2_Batt = co2_batt
[Simulator]
    loop_interval = 2.5
    mode = simulator
    #mode = generator
[StdRESTful]
    [[StationRegistry]]
    [[AWEKAS]]
        enable = false
    [[CWOP]]
        enable = false
    [[PWSweather]]
        enable = false
    [[WOW]]
        enable = false
    [[Wunderground]]
        enable = false
        # to your API key:
        rapidfire = False
[StdReport]
    log_success = True
    log_failure = True
    [[SeasonsReport]]
        skin = Seasons
        enable = false
        skin = Smartphone
        enable = false
    [[MobileReport]]
        skin = Mobile
        enable = false
    [[StandardReport]]
        skin = Rabenwetter
        enable = true
    [[FTP]]
        skin = Ftp
        enable = false
        user = replace_me
        # support this.
        secure_ftp = False
        port = 21
        passive = 1
    [[RSYNC]]
        skin = Rsync
        # will be copied.
        enable = false
        server = replace_me
        user = replace_me
        path = replace_me
        delete = 0
    [[Defaults]]
        lang = en
        [[[Units]]]
            [[[[Groups]]]]
                unused = unused
            # your locale.
            [[[[TimeFormats]]]]
                # day        = %H:%M
                # ephem_day  = %H:%M
                unused = unused
        [[[Labels]]]
            [[[[Generic]]]]
                unused = unused
[StdConvert]
[StdCalibrate]
    [[Corrections]]
        # Example:
        foo = foo + 0.2
[StdQC]
    [[MinMax]]
        inHumidity = 0, 100
        rain = 0, 10, inch
[StdWXCalculate]
    [[Calculations]]
[StdTimeSynch]
    clock_check = 14400
    max_drift = 5
[StdArchive]
    loop_hilo = True
    log_success = True
    log_failure = True
[DataBindings]
    [[wx_binding]]
[Databases]
    [[archive_sqlite]]
    # MySQL
    [[archive_mysql]]
[DatabaseTypes]
    [[SQLite]]
    [[MySQL]]
        host = localhost
        user = weewx
  password = weewx
[Engine]
    [[Services]]
        data_services = ,
Zuletzt geändert von olicat am 21 Feb 2022, 07:39, insgesamt 2-mal geändert.
wetterkunde
Ich habe die confic jetzt so geändert
jetzt liegt der Fehler in Zeile 52
-- A start job for unit weewx.service has begun execution.
-- The job identifier is 82591.
Feb 18 22:47:06 ncserver weewxd[220488]: Error parsing config file: Duplicate keyword name at line 52. File /home/weewx/weewx.conf
Feb 18 22:47:06 ncserver weewxd[220488]:     ****  Traceback (most recent call last):
Feb 18 22:47:06 ncserver weewxd[220488]:     ****    File "/home/weewx/bin/weewxd", line 88, in main
Feb 18 22:47:06 ncserver weewxd[220488]:     ****      config_path, config_dict = weecfg.read_config(options.config_path, list(args))
Feb 18 22:47:06 ncserver weewxd[220488]:     ****    File "/home/weewx/bin/weecfg/__init__.py", line 142, in read_config
Feb 18 22:47:06 ncserver weewxd[220488]:     ****      config_dict = configobj.ConfigObj(config_path,
Feb 18 22:47:06 ncserver weewxd[220488]:     ****    File "/usr/lib/python3/dist-packages/configobj.py", line 1229, in __init__
Feb 18 22:47:06 ncserver weewxd[220488]:     ****      self._load(infile, configspec)
Feb 18 22:47:06 ncserver weewxd[220488]:     ****    File "/usr/lib/python3/dist-packages/configobj.py", line 1318, in _load
Feb 18 22:47:06 ncserver weewxd[220488]:     ****      raise error
Feb 18 22:47:06 ncserver weewxd[220488]:     ****  configobj.DuplicateError: Duplicate keyword name at line 52. File /home/weewx/weewx.conf
Feb 18 22:47:06 ncserver systemd[1]: weewx.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Sorry, diese doppelte Zeile habe ich uebersehen.
Loesch bitte die Zeile 52.
Und (sicherheitshalber) ersetze das ä mit ae in Zeile 71 (diese Portnummer weil die Daten via FOSHKplugin kommen, default wäre 80).
Man kann eine weewx.conf recht gut mit bordeigenen Mitteln pruefen:
 wee_debug --config=/path/to/weewx.conf --info
Nach obigen Aenderungen wird bei mir hier kein Fehler gemeldet - die Config sollte somit fuer weewx ok sein.
Ich habe die weewx.conf im oberen Beitrag ersetzt - Du kannst also auch diese nehmen.
wetterkunde
Ich habe die config geändert und überprüft
root@ncserver:/home/weewx# wee_debug --config=/path/to/weewx.conf --info
  File "/usr/share/weewx/wee_debug", line 431, in <module>
    main()
  File "/usr/share/weewx/wee_debug", line 113, in main
    config_path, config_dict = weecfg.read_config(options.config_path, args)
  File "/usr/share/weewx/weecfg/__init__.py", line 138, in read_config
    config_path = find_file(config_path, args,
  File "/usr/share/weewx/weecfg/__init__.py", line 113, in find_file
    raise IOError("%s is not a file" % file_path)
OSError: /path/to/weewx.conf is not a file
es läuft noch nicht.
/path/to/ ist als Platzhalter fuer den Pfad der Config-Datei in Deiner Installation gedacht.
Bei mir ist dies der default-Pfad /etc/weewx/weewx.conf.
Wenn das bei Dir auch so ist, starte die Pruefung der Konfiguration mit:
wee_debug --config=/etc/weewx/weewx.conf --info
Falls Deine Konfigurationsdatei von weewx an anderer Stelle liegt, passe den Pfad entsprechend an.
wetterkunde
Ich habe ein weewx.conf in etc/weewx und in home/weewx kann ich die dann in home/weewx löschen?
Hier habe ich die Prüfung durchlaufen lassen. Ich kann keinen Fehler sehen.
Using verbosity=1, displaying most info
wee_debug output will be sent to stdout(console)
Using configuration file /etc/weewx/weewx.conf
Using database binding 'wx_binding', which is bound to database 'archive_sqlite'
System info
  Platform:       Linux-5.4.0-100-generic-x86_64-with-glibc2.29
  Python Version: 3.8.10
Load Information
  1 minute load average:  0.19
  5 minute load average:  0.13
  15 minute load average: 0.13
General Weewx info
  Weewx version 4.6.2 detected.
Station info
  Station type: Interceptor
  Driver:       user.interceptor
Driver info
[Interceptor]
    port = 8573    # diese Portnummer weil die Daten via FOSHKplugin kommen, default waere 80
    iface = eth0
    #iface = wlan0
        co2 = co2
        co2_Temp = tf_co2
        co2_Hum = humi_co2
        co2_Batt = co2_batt
Currently installed extensions
Extension Name    Version   Description
interceptor       0.54      Capture weather data from HTTP requests
wh23xx            0.14      Collect data from wh23xx weather stations
Archive info
  Database name:        weewx.sdb
  Table name:           archive
  Version               4.0
  Unit system:          1 (US)
  First good timestamp: 2022-02-15 16:10:00 UTC (1644941400)
  Last good timestamp:  2022-02-17 23:25:00 UTC (1645140300)
  Number of records:    608
  weewx (weewx.conf) is set to use an archive interval of 300 seconds.
  The station hardware was not interrogated in determining archive interval.
Databases configured in weewx.conf
  Database driver:      weedb.sqlite
  Database driver:      weedb.mysql
  Database host:        localhost
Parsed and obfuscated weewx.conf
debug = 0
log_success = True
log_failure = True
socket_timeout = 20
version = 4.6.2
[Station]
    station_url = XXX obfuscated by wee_debug XXX
    rain_year_start = 1
    week_start = 0
[Interceptor]
    iface = eth0
    #iface = wlan0
        co2 = co2
        co2_Temp = tf_co2
        co2_Hum = humi_co2
        co2_Batt = co2_batt
[Simulator]
    loop_interval = 2.5
    mode = simulator
    #mode = generator
[StdRESTful]
    [[StationRegistry]]
    [[AWEKAS]]
        enable = false
        username = XXX obfuscated by wee_debug XXX
        password = XXX obfuscated by wee_debug XXX
    [[CWOP]]
        enable = false
        station = XXX obfuscated by wee_debug XXX
    [[PWSweather]]
        enable = false
    [[WOW]]
        enable = false
    [[Wunderground]]
        enable = false
        # to your API key:
        api_key = XXX obfuscated by wee_debug XXX
        rapidfire = False
[StdReport]
    log_success = True
    log_failure = True
    [[SeasonsReport]]
        skin = Seasons
        enable = false
        skin = Smartphone
        enable = false
    [[MobileReport]]
        skin = Mobile
        enable = false
    [[StandardReport]]
        skin = Rabenwetter
        enable = true
    [[FTP]]
        skin = Ftp
        enable = false
        user = XXX obfuscated by wee_debug XXX
        # support this.
        secure_ftp = False
        port = 21
        passive = 1
    [[RSYNC]]
        skin = Rsync
        # will be copied.
        enable = false
        server = replace_me
        path = replace_me
        delete = 0
    [[Defaults]]
        lang = en
        [[[Units]]]
            [[[[Groups]]]]
                unused = unused
            # your locale.
            [[[[TimeFormats]]]]
                # day        = %H:%M
                # ephem_day  = %H:%M
                unused = unused
        [[[Labels]]]
            [[[[Generic]]]]
                unused = unused
[StdConvert]
[StdCalibrate]
    [[Corrections]]
        # Example:
        foo = foo + 0.2
[StdQC]
    [[MinMax]]
        inHumidity = 0, 100
        rain = 0, 10, inch
[StdWXCalculate]
    [[Calculations]]
[StdTimeSynch]
    clock_check = 14400
    max_drift = 5
[StdArchive]
    loop_hilo = True
    log_success = True
    log_failure = True
[DataBindings]
    [[wx_binding]]
[Databases]
    [[archive_sqlite]]
    # MySQL
    [[archive_mysql]]
[DatabaseTypes]
    [[SQLite]]
    [[MySQL]]
        host = localhost
[Engine]
    [[Services]]
        data_services = ,
wee_debug report successfully generated
Ich weiss ja nicht, mit welcher Config bei Dir weewx gestartet wird.
Mach mal bitte auf der Konsole ein
sudo ps -ax|grep weewx
- da solte Dir die genutzte Config angezeigt werden, sofern der Dienst laeuft.
Ansonsten eben erst mit
sudo service weewx start
den Dienst starten. Und dann nochmal mit ps ax usw. pruefen.
Laeuft denn nun weewx? Oder wirft der noch irgendwelche Fehler?
wetterkunde
#20
FWD_URL = ipadresse:8573 habe ich in foshkplugin.conf eingegeben
In der ws views app habe ich auch alles eingegeben.
Es werden noch keine Daten an weewx übertragen.
http://poehlwetter.ddns.net/public_html
