Hier das log über ca. 5 min
root@raspberrypi:~# sudo tail -f /var/log/syslog
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.engine: Loading service weewx.engine.StdReport
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.engine: 'pyephem' detected, extended almanac data is available
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.engine: Finished loading service weewx.engine.StdReport
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO __main__: Starting up weewx version 5.2.0
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.engine: Station does not support reading the time
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.engine: Using binding 'wx_binding' to database 'weewx_ecowitt.sdb'
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.manager: Starting backfill of daily summaries
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.manager: Daily summaries up to date
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.engine: Starting main packet loop.
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:15:48 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:15:58 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126165, 'usUnits': 1}
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126165, 'usUnits': 1}
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:16:15 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:20 raspberrypi foshkplugin[680]: get-request from 192.168.178.118: /FOSHKplugin/fwdstat
Nov 14 14:16:22 raspberrypi foshkplugin[680]: get-request from 192.168.178.118: /FOSHKplugin/f
Nov 14 14:16:25 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:35 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:45 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:55 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:01 raspberrypi CRON[18277]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 14 14:17:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126229, 'usUnits': 1}
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126229, 'usUnits': 1}
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:17:19 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:29 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:39 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:49 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:59 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126293, 'usUnits': 1}
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126293, 'usUnits': 1}
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:18:23 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:33 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:43 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:53 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:03 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126357, 'usUnits': 1}
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126357, 'usUnits': 1}
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:19:27 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:37 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:47 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:57 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:20:07 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:20:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126422, 'usUnits': 1}
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126422, 'usUnits': 1}
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: INFO weewx.manager: Added record 2025-11-14 14:20:00 CET (1763126400) to database 'weewx_ecowitt.sdb'
Nov 14 14:20:21 raspberrypi weewxd[18265]: INFO weewx.manager: Added record 2025-11-14 14:20:00 CET (1763126400) to daily summary in 'weewx_ecowitt.sdb'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: No database specified. Augmentation from database skipped.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: StationRegistry: Delaying post by 41 seconds
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: Ambient: url: https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?action=updateraw&ID=IJLICH16&PASSWORD=XXX&softwaretype=weewx-5.2.0&dateutc=2025-11-14%2013%3A20%3A00&dailyrainin=0.00
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: Wunderground-PWS url: 'https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?action=updateraw&ID=IJLICH16&PASSWORD=Tontoft43&softwaretype=weewx-5.2.0&dateutc=2025-11-14%2013%3A20%3A00&dailyrainin=0.00'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running reports for latest time in the database.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running report 'SmartphoneReport'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Found configuration file /etc/weewx1/skins/Smartphone/skin.conf for report 'SmartphoneReport'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Cannot read localization file /etc/weewx1/skins/Smartphone/lang/de.conf for report 'SmartphoneReport': Config file not found: "/etc/weewx1/skins/Smartphone/lang/de.conf".
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: **** Using defaults instead.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Unable to set locale 'de': unsupported locale setting. Using default.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running generators for report 'SmartphoneReport' in directory '/etc/weewx1/skins/Smartphone' with locale 'en_GB.UTF-8'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.cheetahgenerator: Using search list ['weewx.cheetahgenerator.Almanac', 'weewx.cheetahgenerator.Current', 'weewx.cheetahgenerator.DisplayOptions', 'weewx.cheetahgenerator.Extras', 'weewx.cheetahgenerator.Gettext', 'weewx.cheetahgenerator.JSONHelpers', 'weewx.cheetahgenerator.PlotInfo', 'weewx.cheetahgenerator.SkinInfo', 'weewx.cheetahgenerator.Station', 'weewx.cheetahgenerator.Stats', 'weewx.cheetahgenerator.UnitInfo']
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:22 raspberrypi weewxd[18265]: INFO weewx.restx: Wunderground-PWS: Published record 2025-11-14 14:20:00 CET (1763126400)
Nov 14 14:20:23 raspberrypi weewxd[18265]: INFO weewx.cheetahgenerator: Generated 6 files for report SmartphoneReport in 0.71 seconds
Nov 14 14:20:23 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:24 raspberrypi weewxd[18265]: INFO weewx.imagegenerator: Generated 6 images for report SmartphoneReport in 0.94 seconds
Nov 14 14:20:24 raspberrypi weewxd[18265]: INFO weewx.reportengine: Copied 6 files to /var/www/html/weewx1/smartphone
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running report 'MobileReport'
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Found configuration file /etc/weewx1/skins/Mobile/skin.conf for report 'MobileReport'
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Cannot read localization file /etc/weewx1/skins/Mobile/lang/de.conf for report 'MobileReport': Config file not found: "/etc/weewx1/skins/Mobile/lang/de.conf".
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: **** Using defaults instead.
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Unable to set locale 'de': unsupported locale setting. Using default.
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running generators for report 'MobileReport' in directory '/etc/weewx1/skins/Mobile' with locale 'en_GB.UTF-8'
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.cheetahgenerator: Using search list ['weewx.cheetahgenerator.Almanac', 'weewx.cheetahgenerator.Current', 'weewx.cheetahgenerator.DisplayOptions', 'weewx.cheetahgenerator.Extras', 'weewx.cheetahgenerator.Gettext', 'weewx.cheetahgenerator.JSONHelpers', 'weewx.cheetahgenerator.PlotInfo', 'weewx.cheetahgenerator.SkinInfo', 'weewx.cheetahgenerator.Station', 'weewx.cheetahgenerator.Stats', 'weewx.cheetahgenerator.UnitInfo']
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:24 raspberrypi weewxd[18265]: INFO weewx.cheetahgenerator: Generated 1 files for report MobileReport in 0.23 seconds
Nov 14 14:20:25 raspberrypi weewxd[18265]: INFO weewx.imagegenerator: Generated 4 images for report MobileReport in 0.62 seconds
Nov 14 14:20:25 raspberrypi weewxd[18265]: INFO weewx.reportengine: Copied 2 files to /var/www/html/weewx1/mobile
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Report 'StandardReport' not enabled. Skipping.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Report 'SeasonsReport' not enabled. Skipping.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Report 'SeasonsEcowitt' not enabled. Skipping.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running report 'neowx'
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Found configuration file /etc/weewx1/skins/neowx-material/skin.conf for report 'neowx'
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Cannot read localization file /etc/weewx1/skins/neowx-material/lang/de.conf for report 'neowx': Config file not found: "/etc/weewx1/skins/neowx-material/lang/de.conf".
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: **** Using defaults instead.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Unable to set locale 'de': unsupported locale setting. Using default.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running generators for report 'neowx' in directory '/etc/weewx1/skins/neowx-material' with locale 'en_GB.UTF-8'
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.cheetahgenerator: Using search list ['weewx.cheetahgenerator.Almanac', 'weewx.cheetahgenerator.Current', 'weewx.cheetahgenerator.DisplayOptions', 'weewx.cheetahgenerator.Extras', 'weewx.cheetahgenerator.Gettext', 'weewx.cheetahgenerator.JSONHelpers', 'weewx.cheetahgenerator.PlotInfo', 'weewx.cheetahgenerator.SkinInfo', 'weewx.cheetahgenerator.Station', 'weewx.cheetahgenerator.Stats', 'weewx.cheetahgenerator.UnitInfo']
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:32 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Florian
