FOSHKplugin Variablen nicht immer verfügbar
Für allgemeine Software
Werner
Danksagung erhalten: 50 mal
Re: FOSHKplugin Variablen nicht immer verfügbar
Beitrag von Werner »
Ich habe gerade festgestellt, dass beim GW2000 bei mir auch die Signale fehlen
Kommando zurück - jetzt sind die Signale da, um 17:12 erfolgte ja der Neutstart von FOSHKplugin
26.04.2024 17:12:27.663 <OK> FOSHKplugin v0.10 Beta 240401 stopped
26.04.2024 17:12:30.506 <OK> FOSHKplugin v0.10 Beta 240401 started
26.04.2024 17:12:30.507 <OK> using configuration file /opt/FOSHKplugin3/foshkplugin.conf
26.04.2024 17:12:30.508 <OK> log level set to WARNING (out of ERROR, WARNING, INFO, ALL (default))
26.04.2024 17:12:30.508 <OK> Logging is globally enabled (loglog: True, sndlog: True, rawlog: False; loglevel: WARNING - to disable set LOG_ENABLE = False in config
26.04.2024 17:12:30.509 <OK> loaded stundenwerte from /opt/FOSHKplugin3/FOSHKplugin-8083-stundenwerte.pkl (675)
26.04.2024 17:12:30.510 <OK> storm warning activated, will warn if air pressure rises/drops more than 1.75 hPa/hour or 3.75hPa/3hr with expiry time of 60 minutes
26.04.2024 17:12:30.511 <OK> loaded min/max values from /opt/FOSHKplugin3/FOSHKplugin-8083-minmax.pkl (230)
26.04.2024 17:12:30.513 <OK> report watchdog activated, will warn if weather station did not report within 10 send-intervals
26.04.2024 17:12:30.513 <OK> battery warning disabled - to enable set BATTERY_WARNING = True in config
26.04.2024 17:12:30.514 <OK> thunderstorm warning activated, will warn if lightning sensor WH57 present, count of lightnings is more than 1 and distance is less or equal 30km with expiry time of 15 minutes
26.04.2024 17:12:30.514 <OK> leakage warning disabled - to enable set LEAKAGE_WARNING = True in config
26.04.2024 17:12:30.514 <OK> CO2 warning disabled - to enable set CO2_WARNING = True in config
26.04.2024 17:12:30.515 <OK> interval warning disabled - to enable set INTVL_WARNING = True in config
26.04.2024 17:12:30.515 <OK> reboot warning enabled, will warn if station reboot is detected via key runtime - to disable set REBOOT_WARNING = False in config
26.04.2024 17:12:30.516 <OK> automatic save/restore for lightning-data enabled - to disable set FIX_LIGHTNING = False in config
26.04.2024 17:12:30.516 <OK> enhanced sunhours calculation with dynamic threshold enabled
26.04.2024 17:12:30.516 <OK> additional dew point calculation (indoor sensor, WH31, WH45) is deactivated - to enable set Export\ADD_DEWPT = True in config
26.04.2024 17:12:30.517 <OK> additional spread calculation (indoor sensor, WH31, WH45) is deactivated - to enable set Export\ADD_SPREAD = True in config
26.04.2024 17:12:30.639 <OK> additional output of the signal quality activated - to disable set Export\ADD_SIGNAL = False in config
26.04.2024 17:12:30.640 <OK> FWD warning enabled, warns if a forward had 10 (specified globally or individually by FWD_WARNINT) unsuccessful attempts - to disable set FWD_WARNING = False in config
26.04.2024 17:12:30.661 <OK> local http-socket 192.168.0.133:8083 bound
26.04.2024 17:12:30.662 <OK> local UDP-socket 192.168.0.133:12344 bound
26.04.2024 17:12:30.662 <OK> remote UDP-sending disabled
26.04.2024 17:12:30.663 <OK> open CSV-file /data/FOSHKplugin/ecowitt3.csv
26.04.2024 17:12:30.663 <OK> write daily values to CSV-dayfile /data/FOSHKplugin/dayfile3.csv
26.04.2024 17:12:48.271 <OK> CSV-header-file /tmp/FOSHKplugin-8083.csvheader written
Ist mir bisher gar nicht aufgefallen, da Sie bei der WS3910 immer vorhanden sind.
Allerdings hat Wilfried schon eine neuere Beta (240419) ich nutze die 240401
Hat sich bedankt: 45 mal
Danksagung erhalten: 520 mal
Ich habe eine mögliche Problemquelle identifiziert und arbeite an einer Lösung.
Es ist KEINE offizielle Beta - ich habe noch ein, zwei Baustellen im Source, die soweit aber funktionieren sollten. Auch ist das Paperwork noch nicht fertig. Das Problem mit den fehlenden Signal-Werten sollte jedoch damit behoben sein.
https://foshkplugin.phantasoft.de/files ... 240426.zip
Update wie ueblich via:
sudo -u username ./generic-FOSHKplugin-install.sh -upgrade generic-FOSHKplugin-0.0.10Beta240426.zip
sudo -u username ./generic-FOSHKplugin-install.sh -repair
Viel Erfolg und gerne eine Rueckmeldung!
Danke!
moppedhausi
Hat sich bedankt: 109 mal
Beitrag von moppedhausi »
Guten Morgen Oliver,
die Signalwerte sind da. :thumbup: :D
Ob auch die sunminswerte da sind, kann ich über Tag erst sehen.
@Edit:
die sunmins Werte fehlen leider noch:
sunhours = 0.26
$sunmins = 0
exxes
Hat sich bedankt: 8 mal
Beitrag von exxes »
Hallo Oliver,
bei mir das selbe. Nach dem Update sind die Signalwerte vorhanden. :thumbup:
Sunmins fehlern noch.
Mit lieben Grüßen aus der wunderschönen Eifel, Thomas https://www.Kreuzau24.de
Ecowitt WittBoy GW2001 / Davis Vantage Pro2 aktiv Plus / Raspberry Pi 4 Modell B 8GB / Personal Weather Tablet / CumulusMX v4.6.1 build 4121
Fehlen die sunmins nur bei der Tagfile-Erzeugung oder wird auch per http://ipaddress0:port/getvalue?key=sunmins oder direkt bei http://ipaddress:port/ nur eine 0 ausgegeben?
Werner
Vor dem Updaten haben die Signale wieder gefehlt.
Nach dem Update sind sie aber auch nicht wiedergekommen (gestern schon)
Auch nach einem zweiten Restart nicht.
27.04.2024 16:36:00.069 <OK> FOSHKplugin v0.10 Beta 240401 stopped
27.04.2024 16:36:04.609 <OK> FOSHKplugin v0.10 Beta 240426 started
27.04.2024 16:36:04.612 <OK> using configuration file /opt/FOSHKplugin3/foshkplugin.conf
27.04.2024 16:36:04.612 <OK> log level set to WARNING (out of ERROR, WARNING, INFO, ALL (default))
27.04.2024 16:36:04.613 <OK> Logging is globally enabled (loglog: True, sndlog: True, rawlog: False; loglevel: WARNING - to disable set LOG_ENABLE = False in config
27.04.2024 16:36:04.614 <OK> loaded stundenwerte data from /opt/FOSHKplugin3/FOSHKplugin-8083-stundenwerte.pkl (675)
27.04.2024 16:36:04.615 <OK> storm warning activated, will warn if air pressure rises/drops more than 1.75 hPa/hour or 3.75hPa/3hr with expiry time of 60 minutes
27.04.2024 16:36:04.616 <OK> loaded min/max values from /opt/FOSHKplugin3/FOSHKplugin-8083-minmax.pkl (230)
27.04.2024 16:36:04.632 <OK> report watchdog activated, will warn if weather station did not report within 10 send-intervals
27.04.2024 16:36:04.632 <OK> battery warning disabled - to enable set BATTERY_WARNING = True in config
27.04.2024 16:36:04.633 <OK> thunderstorm warning activated, will warn if lightning sensor WH57 present, count of lightnings is more than 1 and distance is less or equal 30km with expiry time of 15 minutes
27.04.2024 16:36:04.633 <OK> leakage warning disabled - to enable set LEAKAGE_WARNING = True in config
27.04.2024 16:36:04.634 <OK> CO2 warning disabled - to enable set CO2_WARNING = True in config
27.04.2024 16:36:04.634 <OK> interval warning disabled - to enable set INTVL_WARNING = True in config
27.04.2024 16:36:04.634 <OK> reboot warning enabled, will warn if station reboot is detected via key runtime - to disable set REBOOT_WARNING = False in config
27.04.2024 16:36:04.635 <OK> automatic save/restore for lightning-data enabled - to disable set FIX_LIGHTNING = False in config
27.04.2024 16:36:04.635 <OK> enhanced sunhours calculation with dynamic threshold enabled
27.04.2024 16:36:04.635 <OK> additional dew point calculation (indoor sensor, WH31, WH45) is deactivated - to enable set Export\ADD_DEWPT = True in config
27.04.2024 16:36:04.636 <OK> additional spread calculation (indoor sensor, WH31, WH45) is deactivated - to enable set Export\ADD_SPREAD = True in config
27.04.2024 16:36:04.753 <OK> additional output of the signal quality activated - to disable set Export\ADD_SIGNAL = False in config
27.04.2024 16:36:04.754 <OK> FWD warning enabled, warns if a forward had 10 (specified globally or individually by FWD_WARNINT) unsuccessful attempts - to disable set FWD_WARNING = False in config
27.04.2024 16:36:04.760 <OK> local http-socket 192.168.0.133:8083 bound
27.04.2024 16:36:04.760 <OK> local UDP-socket 192.168.0.133:12344 bound
27.04.2024 16:36:04.761 <OK> remote UDP-sending disabled
27.04.2024 16:36:04.761 <OK> open CSV-file /data/FOSHKplugin/ecowitt3.csv
27.04.2024 16:36:04.762 <OK> write daily values to CSV-dayfile /data/FOSHKplugin/dayfile3.csv
27.04.2024 16:36:18.725 <OK> CSV-header-file /tmp/FOSHKplugin-8083.csvheader written
27.04.2024 16:48:19.249 <OK> local UDP-socket 192.168.0.133:12344 closed
27.04.2024 16:48:19.249 <OK> close CSV-file /data/FOSHKplugin/ecowitt3.csv
27.04.2024 16:48:19.259 <OK> wrote stundenwerte to /opt/FOSHKplugin3/FOSHKplugin-8083-stundenwerte.pkl (675)
27.04.2024 16:48:19.262 <OK> wrote min/max values to /opt/FOSHKplugin3/FOSHKplugin-8083-minmax.pkl (230)
27.04.2024 16:48:19.264 <OK> wrote lasthour data to /opt/FOSHKplugin3/FOSHKplugin-8083-lasthour.pkl (10)
27.04.2024 16:48:19.264 <OK> FOSHKplugin v0.10 Beta 240426 stopped
moppedhausi
olicat hat geschrieben: 27 Apr 2024, 17:17
Hallo Oliver,
sunmins fehlt bei http://ipaddress:port/
bei http://ipaddress0:port/getvalue?key=sunmins wird eine 0 ausgegeben.
