Hi
The forecast is displaying two flashing rain clouds.
Is the flashing normal or an issue?
Thanks
Bresser WiFi Clearview 7in1 Flashing
AndyChafer
- Rolf
- Hat sich bedankt: 12 mal
- Danksagung erhalten: 8 mal
Re: Bresser WiFi Clearview 7in1 Flashing
Hi,
the flashing is an indication of stronger airpressure changes.
Use "Alert" at the back several times and raise the difference value, then the flashing appears less often.
My experience: patience is required, the flashing stops after the next pressure change, up or down.
Mit Grüßen,
