WS-2300 communication errors
Begonnen von osa, 29.01.2006, 15:31:30
osa
Sorry for english, but maybe somebody here can help me.
I have a problem when reading from WS2300.
I have found an info with such problem on this forum:
"Have someone found the ideal timing for the communication?
I see that the WS2300 quite often fail in the communication and I wonder if it is a timing issue."
here:
http://www.wetterstationen.info/phpBB/viewtopic.php?t=1715&postdays=0&postorder=asc&start=15&sid=ca8e8be425d14e71ad73a6310baaa59e
Has somebody solved the problem?
Best regards,
Andrew
osetroff@mail.ru
P.S. I'll be very thankfull for an answer.
It is important for me.
sandstorm3
Hi,
Which software do you use? I1m using newest version of Weather Display and there are only few problems with the WS 2300.
can you tell more please
best regards
Walter :kalt:
osa
I use Delphi (pascal) to communicate with WS2300 through PC’s com port.
I can give my sources to anybody.
Example of my problem:
I  send $06 and recieve $02,
then send $82 and there is no answer.
But next time all is ok:
I send in hex: 06 82 8E 9E 8E CA
and recieve: 02 00 13 27 33 32 60 51 B1 (for example, because it’s a temperature)
What is the reason?
I use another program thread to recieve data.
And my sources work perfect with another device through com port.
Maybe somebody knows something about sync/resync process of WS2300?
