Seite 1 von 2
CumulusMX startet nicht mehr
Verfasst: 08 Nov 2024, 16:04
von c_beller
Hallo Experten,
stehe grad komplett auf dem Schlauch: CumulusMX läuft auf einem Win10-Rechner. Nachdem ich Windows neu installieren musste, startet CumulusMX nicht mehr. In der Windows Firewall habe ich CumulusMX freigegeben, aber es startet einfach nicht. Was übersehe ich?
LG, Christian
Re: CumulusMX startet nicht mehr
Verfasst: 08 Nov 2024, 17:07
does it not start ?
Or you can't connect to the interface ?
Is Cumulus.exe active in the Windows Taskmanager ?
Verfasst: 08 Nov 2024, 17:10
von c_beller
it is not active in the task manager
Verfasst: 08 Nov 2024, 17:11
c_beller hat geschrieben: 08 Nov 2024, 17:10
what does the session log say ?
...\CumulusMX\Mxdiags
do you have the .NET components installed on your Win10 PC ?
what version of CMX have you installed ?
Verfasst: 08 Nov 2024, 18:28
von c_beller
The latest logfile attached, although a couple of days old...
I am running the current version of CMX.
.NET is installed on my PC
Verfasst: 08 Nov 2024, 18:39
von c_beller
I am afraid that something in the firewall setting of Windows10 is wrong.
I installed CMX on another drive, started it and then the windows popped up saying that the computer has been protected by Windows as the app has an unknown source.
Anyway, when continuing to instruct windows to execute the app nothing happens...
Verfasst: 08 Nov 2024, 21:40
von c_beller
short update: It can't be the firewall, since I switched it off and still CMX doesn't start.
Verfasst: 08 Nov 2024, 23:30
how do you start it ?
open a console window with admin rights (so-called elevated prompt) and then go to the CumulusMX directory
e.g.
what happens ?
Verfasst: 09 Nov 2024, 13:28
von c_beller
Thanks Gyvate, for your continous help. Now, this is strange is strange. Wehn I follow your proposal it says that .NET is not installed, although I see it active in the Win10 features. How can that be???
Verfasst: 09 Nov 2024, 13:32
von c_beller
So, it seems, that .NET is already there... wrong version?
