Konfiguration weewx interceptor zerschossen
Jose1701
Re: Konfiguration weewx interceptor zerschossen
#41
Beitrag von Jose1701 »
Gute Idee.
Hier das log über ca. 5 min
root@raspberrypi:~# sudo tail -f /var/log/syslog
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.engine: Loading service weewx.engine.StdReport
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.engine: 'pyephem' detected, extended almanac data is available
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.engine: Finished loading service weewx.engine.StdReport
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO __main__: Starting up weewx version 5.2.0
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.engine: Station does not support reading the time
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.engine: Using binding 'wx_binding' to database 'weewx_ecowitt.sdb'
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.manager: Starting backfill of daily summaries
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.manager: Daily summaries up to date
Nov 14 14:15:38 raspberrypi weewxd[18265]: INFO weewx.engine: Starting main packet loop.
Nov 14 14:15:38 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:15:48 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:15:58 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126165, 'usUnits': 1}
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126165, 'usUnits': 1}
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:16:05 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:16:15 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:20 raspberrypi foshkplugin[680]: get-request from 192.168.178.118: /FOSHKplugin/fwdstat
Nov 14 14:16:22 raspberrypi foshkplugin[680]: get-request from 192.168.178.118: /FOSHKplugin/f
Nov 14 14:16:25 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:35 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:45 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:16:55 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:01 raspberrypi CRON[18277]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Nov 14 14:17:05 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126229, 'usUnits': 1}
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126229, 'usUnits': 1}
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:17:09 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:17:19 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:29 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:39 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:49 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:17:59 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:09 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126293, 'usUnits': 1}
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126293, 'usUnits': 1}
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:18:13 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:18:23 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:33 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:43 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:18:53 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:03 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:13 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126357, 'usUnits': 1}
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126357, 'usUnits': 1}
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:19:17 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:19:27 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:37 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:47 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:19:57 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:20:07 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:20:17 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: GET:
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw data:
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: raw packet: {'dateTime': 1763126422, 'usUnits': 1}
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: mapped packet: {'dateTime': 1763126422, 'usUnits': 1}
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'luminosity' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws80_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws90_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'ws85_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'wh54_ch1_sig' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'heap' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_distance' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: DEBUG weewx.engine: StdCalibrate type or name error in LOOP packet: name 'lightning_strike_count' is not defined
Nov 14 14:20:21 raspberrypi weewxd[18265]: INFO weewx.manager: Added record 2025-11-14 14:20:00 CET (1763126400) to database 'weewx_ecowitt.sdb'
Nov 14 14:20:21 raspberrypi weewxd[18265]: INFO weewx.manager: Added record 2025-11-14 14:20:00 CET (1763126400) to daily summary in 'weewx_ecowitt.sdb'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: No database specified. Augmentation from database skipped.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: StationRegistry: Delaying post by 41 seconds
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: Ambient: url: https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?action=updateraw&ID=IJLICH16&PASSWORD=XXX&softwaretype=weewx-5.2.0&dateutc=2025-11-14%2013%3A20%3A00&dailyrainin=0.00
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.restx: Wunderground-PWS url: 'https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?action=updateraw&ID=IJLICH16&PASSWORD=Tontoft43&softwaretype=weewx-5.2.0&dateutc=2025-11-14%2013%3A20%3A00&dailyrainin=0.00'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running reports for latest time in the database.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running report 'SmartphoneReport'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Found configuration file /etc/weewx1/skins/Smartphone/skin.conf for report 'SmartphoneReport'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Cannot read localization file /etc/weewx1/skins/Smartphone/lang/de.conf for report 'SmartphoneReport': Config file not found: "/etc/weewx1/skins/Smartphone/lang/de.conf".
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: **** Using defaults instead.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Unable to set locale 'de': unsupported locale setting. Using default.
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running generators for report 'SmartphoneReport' in directory '/etc/weewx1/skins/Smartphone' with locale 'en_GB.UTF-8'
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.cheetahgenerator: Using search list ['weewx.cheetahgenerator.Almanac', 'weewx.cheetahgenerator.Current', 'weewx.cheetahgenerator.DisplayOptions', 'weewx.cheetahgenerator.Extras', 'weewx.cheetahgenerator.Gettext', 'weewx.cheetahgenerator.JSONHelpers', 'weewx.cheetahgenerator.PlotInfo', 'weewx.cheetahgenerator.SkinInfo', 'weewx.cheetahgenerator.Station', 'weewx.cheetahgenerator.Stats', 'weewx.cheetahgenerator.UnitInfo']
Nov 14 14:20:22 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:22 raspberrypi weewxd[18265]: INFO weewx.restx: Wunderground-PWS: Published record 2025-11-14 14:20:00 CET (1763126400)
Nov 14 14:20:23 raspberrypi weewxd[18265]: INFO weewx.cheetahgenerator: Generated 6 files for report SmartphoneReport in 0.71 seconds
Nov 14 14:20:23 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:24 raspberrypi weewxd[18265]: INFO weewx.imagegenerator: Generated 6 images for report SmartphoneReport in 0.94 seconds
Nov 14 14:20:24 raspberrypi weewxd[18265]: INFO weewx.reportengine: Copied 6 files to /var/www/html/weewx1/smartphone
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running report 'MobileReport'
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Found configuration file /etc/weewx1/skins/Mobile/skin.conf for report 'MobileReport'
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Cannot read localization file /etc/weewx1/skins/Mobile/lang/de.conf for report 'MobileReport': Config file not found: "/etc/weewx1/skins/Mobile/lang/de.conf".
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: **** Using defaults instead.
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Unable to set locale 'de': unsupported locale setting. Using default.
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running generators for report 'MobileReport' in directory '/etc/weewx1/skins/Mobile' with locale 'en_GB.UTF-8'
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.cheetahgenerator: Using search list ['weewx.cheetahgenerator.Almanac', 'weewx.cheetahgenerator.Current', 'weewx.cheetahgenerator.DisplayOptions', 'weewx.cheetahgenerator.Extras', 'weewx.cheetahgenerator.Gettext', 'weewx.cheetahgenerator.JSONHelpers', 'weewx.cheetahgenerator.PlotInfo', 'weewx.cheetahgenerator.SkinInfo', 'weewx.cheetahgenerator.Station', 'weewx.cheetahgenerator.Stats', 'weewx.cheetahgenerator.UnitInfo']
Nov 14 14:20:24 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:24 raspberrypi weewxd[18265]: INFO weewx.cheetahgenerator: Generated 1 files for report MobileReport in 0.23 seconds
Nov 14 14:20:25 raspberrypi weewxd[18265]: INFO weewx.imagegenerator: Generated 4 images for report MobileReport in 0.62 seconds
Nov 14 14:20:25 raspberrypi weewxd[18265]: INFO weewx.reportengine: Copied 2 files to /var/www/html/weewx1/mobile
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Report 'StandardReport' not enabled. Skipping.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Report 'SeasonsReport' not enabled. Skipping.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Report 'SeasonsEcowitt' not enabled. Skipping.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running report 'neowx'
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Found configuration file /etc/weewx1/skins/neowx-material/skin.conf for report 'neowx'
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Cannot read localization file /etc/weewx1/skins/neowx-material/lang/de.conf for report 'neowx': Config file not found: "/etc/weewx1/skins/neowx-material/lang/de.conf".
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: **** Using defaults instead.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Unable to set locale 'de': unsupported locale setting. Using default.
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.reportengine: Running generators for report 'neowx' in directory '/etc/weewx1/skins/neowx-material' with locale 'en_GB.UTF-8'
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.cheetahgenerator: Using search list ['weewx.cheetahgenerator.Almanac', 'weewx.cheetahgenerator.Current', 'weewx.cheetahgenerator.DisplayOptions', 'weewx.cheetahgenerator.Extras', 'weewx.cheetahgenerator.Gettext', 'weewx.cheetahgenerator.JSONHelpers', 'weewx.cheetahgenerator.PlotInfo', 'weewx.cheetahgenerator.SkinInfo', 'weewx.cheetahgenerator.Station', 'weewx.cheetahgenerator.Stats', 'weewx.cheetahgenerator.UnitInfo']
Nov 14 14:20:25 raspberrypi weewxd[18265]: DEBUG weewx.manager: Daily summary version is 4.0
Nov 14 14:20:32 raspberrypi weewxd[18265]: DEBUG user.ecowittcustom: empty queue
Da scheint ja irgendwas nicht zu stimmen ...
Florian
Das Wetter in Jülich: http://www.wetternet.org/
Hat sich bedankt: 44 mal
Danksagung erhalten: 506 mal
#42
Ich finde aber nicht den Grund, warum die Daten nicht auf Deiner Homepage landen.
Die Verbindung zwischen Konsole, FOSHKplugin und WeeWX funktioniert augenscheinlich - die Daten werden von WeeWX entgegengenommen.
Fuer mich ist das also eigentlich ein WeeWX-Problem. Aber wenn es ohne dazwischengeschaltetes FOSHKplugin funktioniert, muss es auch mit FOSHKplugin funktionieren.
Verschiedene Felder (etwa ws80_sig, ws90_sig, heap oder lightning_distance weisen darauf hin, dass nicht alle Anpassungen von Werner fuer die Datenbank uebernommen wurden.
Seltsam erscheinen mir die Felder luminosity und lightning_strike_count - diese werden nicht von FOSHKplugin geliefert.
Ansonsten fehlen irgendwelche Kleinigkeiten (Konfigurationsdateien, locale).
Aber ich kann eben nicht erkennen, warum keine Daten zur Webpage gehen.
Hat sich bedankt: 15 mal
Danksagung erhalten: 618 mal
#43
trage mal in Deiner foshkplugin.conf bei Deinem Forward
FWD_TYPE = RAWEW
ein
danach Neustart von FOSHKplugin
Zuletzt geändert von Gyvate am 14 Nov 2025, 14:36, insgesamt 1-mal geändert.
Jose1701
#44
Ein Fehler in meiner weewx.config?
Habe auch mehrmals alles neu gestartet ...
#45
unsere Posts haben sich überschnitten - lies mal meinen FWD_TYPE Hinweis im vorletzten Post.
Jose1701
#46
Juchu!
Es scheint zu gehen. Die Werte werden wieder angezeigt.
Dankeschön! Aber warum nur ein "raw" Format weitergegeben wird weiß man nicht, oder ....
Florian
#47
in Deinem Syslog standen empfangene Daten drin, die weewx bzw. der Interceptor Treiber (Ecowittcustom Treiber) vom Format her wohl nicht verarbeiten kann. Er braucht den originären Datenstring, den die Konsole schickt.
#48
Das RAWEW ist um etliche - von FOSHKplugin generierte - Felder befreit und entspricht dem Format, wie es von der Konsole kommt.
Bisher habe ich jedoch noch nicht erlebt, dass bei Einsatz des Format-Typs EW WeeWX die Arbeit komplett einstellt!
Fehlermeldungen ueber unbekannte Felder sind klar - die lassen sich durch die Erweiterungen von Werner jedoch beheben.
Ich dachte, Du haettest die Anpassungen der Interceptor-Konfiguration von Werner vollzogen. Da haette dann auch die Datenbank etc. um die neuen Felder erweitert sein sollen.
Ich habe also eigentlich noch immer keine Ahnung, warum Deine Webseite nicht mit Daten beliefert wurde.
Aber vielleicht kann Werner da aufklaeren.
Und wichtig ist vorallem: gut, das es jetzt bei Dir funktioniert.
Jose1701
#49
OK.
Ich bin zumindest froh, dass es wieder geht und bedanke mich noch mal herzlich bei euch. Möglicherweise hat Werner tatsächlich eine Idee.
Vielleicht schaffen wir das mit dem Modul vom MagicMirror irgendwann auch noch. Meine Kenntnisse reichen dafür eher nicht aus.
Florian
#50
Ich bin da dran ...
Wenn ich Deine Konfiguration richtig gesehen habe, sendest Du via WeeWX an WU und Awekas.
Natuerlich koennte man stattdessen auch via FOSHKplugin senden. Dann haette man nur einen zentralen Verteiler und wuerde Abhaengigkeiten reduzieren. Aber erstmal ist es bestimmt gut, zu behalten, was funktioniert.
