Simple Static electricity detector
Begonnen von weather1967, 04.08.2009, 22:50:25
weather1967
Hi
I make a simple static electricity detector ,i want to know at thunderstorm what
it show :D
I decided to put telescopic antenna for better ,the battery i stick with warm
glue
The original concept and design it is from here ,but i use another JFET
tranzistor
http://www.amasci.com/emotor/chargdet.html
Video
http://www.youtube.com/watch?v=D_PB_PShgVc
Photos down side
http://users.otenet.gr/~meteo/project_static-electricity-detector.html
weather1967
Because I see that portable goes well to change and in the house. I decided to make another one above on my roof and with cable in the house and to connect a multimeter in place mA in line with led, and to have it doubly in the console of weather station to see the changes of the stativ electricity at  storms and not only,I will epxeriment   of course at sensitivity  , perhaps and to change the cable antenna, I thought a round piece aluminium 30 cm diameter and 1 mm, to the present you see in foto the materials that I bought today Waterproof box, blue one ply 1,5 mm diameter for antenna, multimeter digital, PCB, the materials (transistor, led, resistance, battery 9 volt for the detector, power supply  9 volt 500 mA for the   supply multimeter, because it battery will finish fast, with patent I will open hole in the multimeter and I will remove cable with nail plug, male jack for the multimeter and cable .
http://i82.servimg.com/u/f82/11/22/64/62/detect17.jpg
chris vreewijk
hello Dimitris,
I like your experiments,please have a look at my detector build from techlib open on top readers versions my detector is the third from above.
detections around 150 km and lot of sensitivity.
I have implemented a jogging step counter to count the strikes.and some more gadgets.
http://www.techlib.com/electronics/lightningpics.htm
please let us know how your experiments are goning on :-)
Kind regards Chris
***davis vantage pro2-running with virtual weather station***
lightning detection  home made techlib.com***1-wire lightning detector powered by weather display***sturmglas =standard recept.
weather1967
Hello Chris and thank you,i know this site ,and congratulation you have make very nice work
My it is not VLF receiver ,just it understand the change to statistic electricity ,i have lightning radar longe range ,but this where i make it is for near distances
Because I see that portable goes well to change and in the house. I decided to make another one above on my roof and with cable in the house and to connect a multimeter in place mA in line with led, and to have it doubly in the console of weather station to see the changes of the static electricity at  storms and not only,I will epxeriment   of course at sensitivity  , perhaps and to change the cable antenna, I thought a round piece aluminium 30 cm diameter and 1 mm, to the present you see in foto the materials that I bought today Waterproof box, blue one ply 1,5 mm diameter for antenna, multimeter digital, PCB, the materials (transistor, led, resistance, battery 9 volt for the detector, power supply  9 volt 500 mA for the   supply multimeter, because it battery will finish fast, with patent I will open hole in the multimeter and I will remove cable with nail plug, male jack for the multimeter and cable .
For today i am finnish the inside part ,and tomorrow i will finish and the conection over to my roof .
http://i82.servimg.com/u/f82/11/22/64/62/detect18.jpg
http://i82.servimg.com/u/f82/11/22/64/62/detect19.jpg
chris vreewijk
hello dimitris,
Ok i was looking forward to see the dish on your roof :confused:  but that photo was not present.
Did your messuraments increased with the 30 cm dish?
And do you need some reversed capacity under the dish like another small plate ?
Maybe I build this one myself :-D
At this moment my project with the Nane detector is still going on you find it on this site under
http://www.wetterstationen.info/phpBB/viewtopic.php?t=16819&highlight=langwellen
so have a look at it.
kind regards Chris
weather1967
Ηi Chris
Very nice project i will read again better the electronic design.
No for this time i do not have build yet the 30 cm disk ,i have for antenna the blue cable one ply 1,5 meters lenght and 1,5 mm diameter,i want to see first the results with cable ,and after i will build the disk .
I will experiment with 100 pF capacitor for antenna  disk ,and with out capasitor.
No i thing just one disk all plate antenna
weather1967
weather1967
I build for base 2 angle brackets 12,5 x 15 cm for touch the antenna at wall over to my roof .
http://i82.servimg.com/u/f82/11/22/64/62/antenn15.jpg
chris vreewijk
hello Dimitris,
Yes I think like that is ok.I have seen more project using a detection plate like yours.
Do you think you can get a certain reference valua so you know activity is low or high ?
like around 100mv as normal without activity ,or in what value are you mesuraments made ?
are you shure you do not need a smaller metal plate under the detection plate as negatice capacity ?
Anyway your project is interresting.  :-P
Krgds Chris
