Building Waterproof box for web camera
Begonnen von weather1967, 30.01.2009, 17:45:25
In
setTimeout("LoadBuffer()", xx);
must be xx the delay time in milliseconds.
20*1000=20.000ms=20s
If you change your interval only change the delay to your upload interval in seconds.
weather1967
I understand it,and i try it,but i do not see any differents from before ,before every 20 sec it make refresh,and now after the new code the same ,anyway thank you
At the moment the image is reloaded 28 times (every 0.7s) before there is a change after 20s. For what? It causes a lot of traffic with no effect.
Every image has around 67kb. Your visitors are loading around 1.8MB every 20s for nothing.
weather1967
MANNY THANKS Dietmar
Now i saw it,and now i fix it ,you are very correct.
One question yet,if i want to up load every 2 or 5 min ,i will have 1000* delay ,and 120 or 300 the var delay ?
Thanks a lot for all,because i do not know about codes  :oops:
Zitat von: "Holli"At the moment the image is reloaded 28 times (every 0.7s) before there is a change after 20s. For what? It causes a lot of traffic with no effect.
Zitat von: "weather1967"One question yet,if i want to up load every 2 or 5 min ,i will have 1000* delay ,and 120 or 300 the var delay ?
Correct.
