Building Waterproof box for web camera
Begonnen von weather1967, 30.01.2009, 17:45:25
weather1967
I build easy and with very low cost a waterproof box for web camera .
The material it is one waterproof box and one glass .Here i have a small project
http://users.otenet.gr/~meteo/project_waterproof-web-camera-box.html
joergeli
Hello Dimitris,
Zitathttp://www.geocities.com/meteoperisteri/webcamerabox.html
Page isn't reachable at the moment - Errormessage: "Sorry, Service Temporarily Unavailable"
Have you seen my "WebCam-House" ?  ;-)
http://www.joergeli.de/cam_technik.php
It's build with drainpipes because I use a normal DV-Camcorder.
As protection for the CCD-Chip I use a self darkening glass which I've got from an Optician, who's a friend of mine.
In the afternoon, when the sun comes around, the glass darkens and protects the Chip from too much radiation.
Greetings from Cold Old Germany ;-)
Jörg
Edit: Now your Pictures are reachable.
Arduino-Bastelseite:
hotec
:top:
Nice job and documentation, Dimitris !
Greetings,
weather1967
Thank you Rolf.
Jorg my server it is from geocities for this reason i do not have many bandwith  :-( ,and if is inside many people shutdown the page,you can try little later,thank you and sorry for this.
Your camera it is very profesional  :top:  :top:  :top:
weather1967
Finnaly for better quality capture , i put Logitech quik cam pro 9000 ,i am very happy with this web camera . :-)
http://users.otenet.gr/~meteo/peristericam.html
Why is the image loaded every second (or oftener) when it changes only every 20 seconds?
weather1967
I have tuning to up load the new icon,every 20 sec,if i undesstood well you question.
Zitat von: "Holli"Why is the image loaded every second (or oftener) when it changes only every 20 seconds?
var delay       =1; <- Delay time in seconds if
setTimeout("LoadBuffer()", 700*delay); <- the multiplicator is set here to 1000.
At the moment the image is reloaded every 0.7s. Set the multiplicator to 1000 und delay to 20, then the image is reloaded when there is a new image. If you change the interval for the image upload e.g. to 15s or 30s you only have to change the delay.
weather1967
Thank you
I do not know it,i do not know well from html codes  :oops: ,
If i understood well 700* delay i must to put 1000 ? and  var delay =1 ?  i must to put 20 ? it is correct ?
And  future  if i want to put 60 sec or 120 sec up load ? what tunings must to do ?
Thank you
